Which Brake proportional valve is needed
I just put the 993TT big brake on the 964 with 993 NB on the rears.
What valve do I need to change to ? I have to much up front right now.
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 08-05-2009, 01:29 PM
Bill Verburg's Avatar
When Porsche installed that set up on 3.6t they used a 60bar p/v, i'd try it w/ none then install that or an adjustable Tilton. none will probably work fine for you.
Bill Verburg
Old 08-06-2009, 04:49 AM
kurquhart's Avatar
Street or track? If the latter, you can also change the bias using different pad compounds. I have the turbo p/v, Pagid Yellow front and Black rear; works well for me.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 08-06-2009, 07:41 AM
Track ,
Bill Thanks how do you go with none?
Do you drill it out or remove it ?Do you have some info on that?
2011 M3 4Door
Old 08-06-2009, 07:35 PM
Originally Posted by deoxford View Post
Track ,
the 964 Cup cars used a brake line #964.355.315.70 which afaik is nla. You can disassemble the existing p/v and remove the guts or I believe many just stretch the existing lines into place.
Bill Verburg
Old 08-07-2009, 04:32 AM
Bill,
Do you have a pic of the valve and a picture of where it is on the car.
I think I know , but I want to make sure .
2011 M3 4Door
Old 08-11-2009, 06:03 AM
Bill,
here's one from a C4, C2 should look similar.
On 993 they are on the output from the abs pump, but on 964 they are in the lines
here's a C4 in situ
Bill Verburg
Old 08-11-2009, 04:42 PM
