Hawktel's Avatar
Trim peice on the side.
I have a piece of broken trim on my 89. I'm showing a picture of it below. The problem I have is, its not the clips that are broken, but the actual trim piece the hooked parts that stick out that the clips hook onto are broken.
I am considering gluing the clips on using the model plastic glue. I don't see another way to affix the clips on to the piece. What do you guys think?
Wrap me up in my old flying jacket,
And give me a joystick to hold, to hold,
And I'll soar once again o'er the trenches
And thus shall my exploits be told.
Old 09-07-2009, 04:08 PM
kurquhart's Avatar
Yes, lots of folks have glued those weak clips in place, using a variety of adhesives.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 09-07-2009, 07:19 PM
Chakka71's Avatar
I had the (like alot of 964 owners) same issue. I used RTV blue to glue the panel to the white fasteners that the piece clips into. It has a little flexiblility(for vibration) when hardened, unlike glue, plus if I needed to take it off you can get it off without too much issue. It's held with no problem for the past 3 track events. I use the RTV for lots of temporary/someday might need to remove parts. Works for me.................
PCA National Instructor
93 RS America (some things done to it....)(gone)
85 Carrera (gone)
06 BMW M5 (gone)
"If you ain't first, your last"
Old 09-08-2009, 04:55 AM
livesportm's Avatar
Ditto above!
Glue worked for now!
Stan D
Old 09-08-2009, 09:53 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
yep, mine are glued on also...
Old 09-08-2009, 05:14 PM
SAM DACOSTA's Avatar
I just did mine on the right side this past weekend as well. I'm noticing a trend on these forums. If something common is happening to one 964 then it's probably happening or happened to allot of others 964's and there's always a fix or solution available. Thanks to all who contribute.
SAM DACOSTA
1990 Porsche 911 Cabriolet (964)
2000 Porsche Boxster (986)
2002 Porsche 911 C4S (996)
Old 09-09-2009, 10:38 AM
