Powder Coating in the Valley
Now that I got my 964 fan all cleaned up I want to powder coat it. Does anyone have a recomendation for a powder coating shop in the San Fernando Valley? West Valley maybe? Thanks all!
Christopher |
Don't forget to mask the edges.
You might search on the main tech board, more folks have done the fan powdercoating there.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Thanks Don!
will do. CW |
Soooo, I got the fan back from Pyramid powder coating and I figured I was a pretty smart guy so I decided to change the fan myself. Boy when am I going to learn. So I didn't have the right 12 point hex to help loosen the belts, so I used a star shaped hex. Now I got the belts off, but I couldn't pull off the fan (like on my 88). So I called my friends over at Asse Motors and come to find out that the fan has to be pulled off with a press. Dooooh! So I put all the belts back on and take my car over to Asse Motors. When they try to remove the belts, I find out because I didn't use a 12 point hex that I stripped the inner threads that you need to hold the fan in place to loosen the fan belts. Soo now I have to not only have to pay for the labor to remove the fan and put on the new powder coated great looking fan, but I got to pay for a new Alternator/ generator. Dooh, Doooh.... But what did I learn, before I ever attempt anything I'm not sure about I'm coming on this chat board to ask. Also I need to buy a 12 point hex, because if my fan belts ever break, ( the tool kit has a new belt, but no 12 point hex) I would be stuck because I couldn't get the belts off. So does anyone know where I can get a 12 point hex?
CW |
Ok then!
CW |
Final results look great
