993rsr
They often do that, RSR rebuild is scheduled for every ~20hrs.
I had the lower fins on my my heads welded up to prevent that sort of thing
serious pron.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Kris 1990 C2 2005 CS http://krisu.smugmug.com/Auto/Porsche |
Forged RSR rocker, adjustment by shim
![]() Stock 993 hydraulic ![]() 993 modified to mechanical ![]() Assembled RSR adjustment by shim
1. What other parts (e.g. valves, head studs, rod bearings) typically need to be replaced at the 20 hour rebuild?
2. What is the rated max RPM?
A 993 RSR sprint motor is 340hp@7000, 380NM@5500 there is a lot of variation depending on the series
Alter Ego Racing
a 97 RSR will be on the market soon. PM me if seriously interested.....
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
RSR head info
Bill. Picture is of 964 RSR head. I assume they are drilled for either 964 or 993 flange configuration. Would that be correct? Thanks!
I know that they first used the 993 exhaust setup on the 964 3.8RS
