-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   993 Tiptronic directly engages 2nd when sloted in D (http://forums.pelicanparts.com/showthread.php?t=519449)
carbuff 01-02-2010 09:50 PM
1995 Carrera facing following issue:
The tiptronic works perfectly on both the steering wheel and the gear shift, but when one engages the gear to D position the gear engages directly to 2nd gear and not 1st.
Any ideas what could be the cause/reason for this? :confused:
LouZ 01-03-2010 06:17 AM
On my 964, this is normal, as it is programmed to start in 2nd when in "D" mode. It would immediately downshift to 1st if the accel is pressed down quickly.
The 2nd gear start is designed to save gas in normal driving.
96740 01-03-2010 08:32 AM
That's normal. If you put it into 3rd instead of D, it will start in first.
carbuff 01-03-2010 08:48 AM
thx guys another one
Any idea how one could restore a windshield wiper assemble set up that is currently on wrong side (not on drives side!)of the windscreen?
Are the internal arms/mechanism connecting to the motor switchable/reversable? Or one needs to get a brand new assembly to make this correction happen thx cheers
aigel 01-03-2010 09:31 AM
Reversing wiper rest position is a popular modification for shorty drivers. ;) This is how the modification is done. I would follow these instructions - backwards:
Wiper reversal
Cheers,
George
carbuff 01-03-2010 10:44 PM
thx a ton aigel
berni29 01-17-2010 01:48 PM
Hi
Just to add that if the car is cold it will pull away in 1st even though in D. Try it!
Berni
