Carerra emblem
Just bought a 01 C2, with a Gemballa spoiler on without any emblem or sticker at the car rear. I had bought a Carerra emblem (already provided with double-sided adhesive tape at its back) ... unfortunately, it was mis-positioned and mis-fixed by an independent car technician ... and it looks quite weird in terms of its position at the car rear.
I'm afraid of damaging the exterior paint if I pull it off by force, how can I re-position / re-fix the emblem? Thanks so much for your advice!
BTW, it's a really wonderful car to drive and to look at!
nefilim
Old 12-23-2004, 01:23 AM
Emblem removal
I Used dental floss between the emblem and the deck lid. It took several pieces to complete the job in less than 4 minutes.
Old 12-23-2004, 08:33 AM
Don Haney's Avatar
Hi Nefilim,
Get the wife's hand held hair drier, warm the emblem until the double sided tape is soft, then gently lift it off the emblem. Sorry, you'll need to buy a new emblem, unless you can find the really thin double face tape and then cut it to match the Carrera script.
Don Haney
don@pelicanparts.com
888-280-7799 Ext 305
1991 C2 Tip - Sold
Old 12-23-2004, 08:40 AM
Smile Emblem removal
Thank you guys.
From your experience, just wanna ask if there will be any "mark" left by the emblem originally positioned on the rear lid ... even after waxing.
Merry X'mas & Happy New Year!
Old 12-23-2004, 06:55 PM
Larry Harris's Avatar
It probably depands on how long the enblem has been on the car, what sun exposure the car has had and the color of the paint.
The longer it is on the car the more possible problem you may have.
Good luck
Lar
2001 Turbo
Old 12-24-2004, 12:40 PM
91C2's Avatar
I hope I can get some answers for this How do I remove the emblem on the hood for my 1991 C2? I also need to remove the windshield washer jets any idea how to remove this as well?
Thanks,
1970 Morris Cooper S, 1973 Mini Clubman GT, 2008 BMW 135i Coupe, 2008 BMW 128i Cabriolet, 1995 BMW M3, 2016 Mazda Miata
Old 11-23-2010, 07:31 PM
Thanks,
The 964 hood emblem is held on by 2 nuts that attach to studs cast as part of the emblem.
Open the hood and there are 2 holes in the hood stiffener pieces, directly under the emblem. a socket (6mm??) will be needed to unscrew and remove the nuts, then just pull the emblem and gasket off.
LouZ
'90 C2 TIP
'08 Cayman S
Old 11-24-2010, 11:46 AM
