996 seats in a 964?
Do they fit?
You could make them fit problem bieng is the electrical side of things might need a good sparky.
Minor mods to track rails and wiring needs to be adjusted, but they do go in. Do a search over on Rennlist or p-car.com.
Thanks guys
I want to put GT3 sport seats in, so electrical is not an issue. What do you have to do to the tracks? |
It's not too bad. You have to grind/cut off the pins about 2/3 the way back on the rails and bend up the front tabs so they are straight. You might just remove those and it's pretty much a bolt in deal after that. You may wire in the seat belt wires so that the car sees that you've buckled up. Up to you I suppose.
