-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   964 Backdate Project (http://forums.pelicanparts.com/showthread.php?t=587511)
G7miami 01-23-2011 09:07 PM
I just got this car from California as a new project. 1990 Carrera 2 with G50 and some backdates. The car was gone through for a Pre Purchase Inspection by John Chambers in Oceanside, CA and he documented that the car had suspension issues and #5 cylinder had 0 lbs pressure on the leak down test and seemed to have a exhaust valve sticking.
I bought it off the internet and had it shipped to Tallahassee for fit and finish issues at G. Davis Auto, a trusted Porsche Mechanic and my brother.
http://forums.pelicanparts.com/uploa...1295845474.jpg
http://forums.pelicanparts.com/uploa...1295845508.jpg
http://forums.pelicanparts.com/uploa...1295845584.jpg
G7miami 01-23-2011 09:16 PM
Things I Liked
The car was overall clean, had the rear seat delete, good base colors, clean car-fax, and upgraded suspension to Bilstein & H&R green springs.
Work had been done to make it a 73 RS clone and the front quarters had been extended, they had made it a long nose, R Gruppe light in the rear, RS door panels, they put the duck tail on and the Carrera logos.
http://forums.pelicanparts.com/uploa...1295846087.jpg
http://forums.pelicanparts.com/uploa...1295846113.jpg
http://forums.pelicanparts.com/uploa...1295846158.jpg
http://forums.pelicanparts.com/uploa...1295846199.jpg
G7miami 01-24-2011 09:06 PM
Things I Did Not Like
I knew immediately the green colors had to go, so I was ready for some changes immediately. I also needed to fix the front suspension issues and #5 cylinder. There were fit, finish and interior issues that I would be getting on.
http://forums.pelicanparts.com/uploa...1295931884.jpg
http://forums.pelicanparts.com/uploa...1295931916.jpg
http://forums.pelicanparts.com/uploa...1295931938.jpg
http://forums.pelicanparts.com/uploa...1295931954.jpg
carslutt 01-25-2011 10:18 AM
looks like a good start for an project
SAM DACOSTA 01-25-2011 01:56 PM
Keep us posted with pictures and updates as you work your way thought the car. I think you've started with a good base car and it can only get better from there.
G7miami 01-25-2011 02:46 PM
Let's get Started
Once the car was delivered to G. Davis Auto in Tallahassee, we got a better look at the car
http://forums.pelicanparts.com/uploa...1295995367.jpg
http://forums.pelicanparts.com/uploa...1295995433.jpg
http://forums.pelicanparts.com/uploa...1295995493.jpg
We decided the car needed new rubber, springs, wheels stripped and repainted.
G7miami 01-25-2011 03:01 PM
Things We Ordered - To Start
Tire Rack
(2) 205/50ZR -17 Continental ExtremeContact DW XL
(2) 255/40ZR -17 Continental ExtremeContact DW
(1) H&R sport-spring (red) #29834
(1) Bilstein hd strut fl 35-052777
(1) Bilstein hd strut fr 35-052784
G7miami 01-26-2011 07:18 AM
Getting Started
We got the car in the air and removed wheels for color change and decided to drop the motor out to rebuild the top end.
http://forums.pelicanparts.com/uploa...1296054696.jpg
Parts Need to be Cleaned
http://forums.pelicanparts.com/uploa...1296054770.jpg
Looking Clean and Pretty - Now the heads were sent to Anchor Atlantic for attention
and the parts were stored on the shelf.
http://forums.pelicanparts.com/uploa...1296054870.jpg
Wheels and Springs arrived.
http://forums.pelicanparts.com/uploa...1296054127.jpg
Rear view with motor out and new springs installed. We realized once we took the front springs off that the prior owner had stripped the heads on the Bilstein shocks and we needed to replace them.
http://forums.pelicanparts.com/uploa...1296054918.jpg
Wheels were stripped of green color and prepped for respray, because of cold weather they were left to dry in a heated room for two days.
http://forums.pelicanparts.com/uploa...1296055067.jpg
G7miami 01-26-2011 12:00 PM
Little Details
Since the colors are white and black, Geoff sent me to Ernie's Alloys to get a set of old center caps and use them to accent the car. Great Idea.
http://forums.pelicanparts.com/uploa...1296071971.jpg
Tires Mounted
http://forums.pelicanparts.com/uploa...1296071993.jpg
G7miami 01-31-2011 11:34 AM
The Wait
Waiting on more parts
G7miami 02-06-2011 11:28 AM
Parts In - Rebuilt Starting Point
Anchor Atlantic and Pelican Parts supplied all the items I needed to get this project back on
track
http://forums.pelicanparts.com/uploa...1297020438.jpg
http://forums.pelicanparts.com/uploa...1297020490.jpg
G7miami 02-10-2011 09:33 PM
New B&B Headers & Exhaust - but I get stuck
So I just got a B&B Exhaust off Pelican (thanks Matt) and my mechanic/builder/brother has an emergency for his biggest client, so I am stuck for about 30 days.
http://forums.pelicanparts.com/uploa...1297402373.jpg
Schwarzeritter 02-10-2011 11:08 PM
Cool project.
rattlsnak 02-11-2011 11:51 AM
very cool. ive thought about doinjg a 964 backdate myself.
BUT, whats with all the 911 rollers in the background picture?????
Don Plumley 02-12-2011 08:01 AM
Nice - looking forward to seeing this.
G7miami 02-13-2011 09:13 PM
Got a few more Porsche projects waiting on funding. Damn Economy and expensive children keep the projects to 1 a year. Last years 69 Firebird 400 RestoMod took almost 1200 hours. Keep watching for the 964 backdated to 74 IROC RSR after I finish this one.
Mike Hall 02-17-2011 08:53 AM
Is G. David Auto the little porsche shop down in Tally? I have been trying to find the place I went to years ago to see if they have any projects or at least some parts I might could use on a 66 912 I just bought.
Mike
G7miami 02-26-2011 10:12 AM
Getting back to Work
So after a little distraction called work, we are back into the project. As always we decided to go a little deeper into the rebuild, and cracked the bottom end to get a peak.
Case Opened
http://forums.pelicanparts.com/uploa...1298743929.jpg
Case Closed
http://forums.pelicanparts.com/uploa...1298743947.jpg
G7miami 05-25-2011 06:16 PM
Coming Along
http://forums.pelicanparts.com/uploa...1306372500.jpg
http://forums.pelicanparts.com/uploa...1306372518.jpg
http://forums.pelicanparts.com/uploa...1306372534.jpg
http://forums.pelicanparts.com/uploa...1306372551.jpg
G7miami 06-22-2011 08:48 PM
Gosh Darn It - When can I drive It
So it is close, but no cigars, worse yet it is 500 miles away so I can even pop in and give it a test drive.
But here are some pictures, just waiting on more PARTS
http://forums.pelicanparts.com/uploa...1308800795.jpg
http://forums.pelicanparts.com/uploa...1308800822.jpg
Need to do a little more figuring on this part
http://forums.pelicanparts.com/uploa...1308800841.jpg
http://forums.pelicanparts.com/uploa...1308800882.jpg
spence88mph 06-23-2011 05:27 AM
3.6 goes in here:
http://forums.pelicanparts.com/uploa...1308831683.jpg
dan79brooklyn 06-23-2011 07:12 AM
Very cool car. I like your changes. What's the interior plan?
G7miami 04-02-2012 03:38 PM
Oh we are getting close to Paint
Coming Along
http://forums.pelicanparts.com/uploa...1333406210.jpg
http://forums.pelicanparts.com/uploa...1333406231.jpg
http://forums.pelicanparts.com/uploa...1333406245.jpg
http://forums.pelicanparts.com/uploa...1333406273.jpg
tdw28210 02-02-2013 06:51 AM
Hey..how did the end up?
GBX 02-05-2013 08:40 AM
Anyone know what front and rear bumper this is?? From what manufacturer that is.
G7miami 07-15-2013 07:21 PM
New Shoes - Fuchs Baby
Delivered today from Germany to Tallahassee, 17" Fuchs 7" fronts and 9" rearshttp://forums.pelicanparts.com/uploa...1373941290.jpg
G7miami 07-15-2013 07:22 PM
Custom made by G. Davis Auto
andy_uranium 07-20-2013 10:15 PM
Wheels look good, have them mounted yet?
GBX 08-02-2013 04:48 PM
Fiberglass?
Nski 08-15-2013 01:24 AM
Great project!
G7miami 01-20-2014 02:01 PM
All steel, one off, custom bodywork
agent00eleven 06-27-2014 12:24 PM
Where did you order these, and what tires/sizes are you going to use?
