1996 993 climate control unit
My climate control unit seems to be making a noise almost like a buzzing noise when the car is running and for some time once the car is off. Does anyone have any idea what is causing this and if so how to correct the problem? Is this a common problem with the 993's? Thanks
Old 12-19-2011, 02:57 PM
Alps Adventurer
Traveller's Avatar
See what you can find in Tore's article...
CCU Repair
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 12-19-2011, 04:06 PM
Opo Opo is offline
How long those noise keeps going after turning car off? And are you sure is not coming from the dashboard?
Old 12-19-2011, 04:28 PM
Alps Adventurer
Traveller's Avatar
The link above tells you.
All the best,
Alex
Old 12-19-2011, 05:29 PM
That link looks very helpful. I will check it out, and hopefully it will solve my issue. The noise i am hearing does sound like it could be that motor running. Thanks for all the help. Ill let you know how i make out.
Old 12-19-2011, 06:08 PM
Good luck with changing the CCU fan. Feel free to ask any questions, my email address is mentioned on my DIY page linked above.
Cheers,
Tore
Old 12-20-2011, 11:15 AM
Send a message via AIM to deekay911 Send a message via Skype™ to deekay911
Take out the CCU and on the back is a small fan. Take the fan off, and lube the fan shaft - noise will go away.
1996 993 C2
1995 968 Cab
1976 Norton 850
Old 12-21-2011, 06:12 AM
