964 quarter window removal
I would appreciate advice on removing 964 quarter window,
because I plan to replace the lower black moulding, which has a couple of "bubbles". |
I removed all the windows in mine prior to repaint. Those quarter window seals are glued in. It is pritty much impossible to remove them without cutting the rubber seal and replacing it. If you can maticulusly sand and paint the trim you might be better off or leave it alone.
+1 cut the seal it will make things soooooooo much better. You will have some cleaning to do the glue is really on there.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
Hey guys , the 964 1/4 rear glass is should not be glued in, just rubber seal, it may two poeple to the safefuly , one person on the side of the car holding the glass while the other is in side pushing out but ,the person inside should fold down the rubber seal so that it is pulled away from the pinch, start at the rear corner , you may have o push very hard , and to reinstall all you need is a thin nylon rope,
Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo Last edited by heliolps2; 02-15-2012 at 05:19 AM.. |
heliolps2, what year 964 did you remove quater windows on that were not glued in. I am curious and I thank you for your answer.
On my 91 it had a sh**t load of glue on driver side only. Pass side only had a little.
Air bag cars have glued in windows, even though the seals are rubber.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
