Oleg Perelet
993 wilwood aluminum brake hat part number or dimensions.
Hello, I'm looking for part numbers for willwood aluminum brake rotor hats that will fit front 993 uprights with 993 calipers and wilwood rotors - 12in(304.8mm)x1.25in(31.75mm).
Wilwood High-Performance Disc Brakes - Rotor Hats If you know of of other manufacturer hats that will work, please post also. Willwood parts are just very easy to get. If nothing off the shelf is available - can you please post dimensions of your custom hats. Oleg. |
here are some specs 5x130 bolt circle 304mm diameter 32mm annulus thickness 103mm hole in the hat for the hub 72mm from the back of the rotor to the front of the hat the best way to do it is to send them a rotor to measure and then replicate as a 2 piece unit
