antiqueronnie's Avatar
964 fuel tank removal help
hello anyone out there ever remove a 964's fuel tank? I have the top figured out but was wondering how to go about the rest? do you have to go underneath and undo the engine lines? thank for any help ronnie
Old 01-17-2012, 02:29 PM
Check out this Evaporator DIY since it requires removing the gas tank.
993 A/C Evaporator replace DIY
Old 01-17-2012, 05:47 PM
Thanks Vandit
that link gave me all the help I needed,,, I am very grateful you save me lots of trial and error,,, mostly error...lol ronnie
Old 01-17-2012, 06:47 PM
Metal Guru
911nut's Avatar
I would add that it isn't necessary to remove the fuel pump. Just disconnect the hose running from the fuel tank to the fuel pump and the return fuel line. Also, this is a good time to replace the vapor line running from the vent valve to the plastic vent line under the car.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-18-2012, 06:28 PM
