Engine Heater Fan Runs Continous
The heater fan in the engine compartment runs continously on my 91 964 and I can feel the heated air through the center vent on the dash pad. Is this problem from a bad relay or other electrical problem? Thanks
Anyone?
It's a complicated system and there are IIRC multiple potential causes for this. You'll have to search, but when you do make sure to check the 964 forum at RennList also.
Sounds like your symptoms.
Heater Blower Fan always on... - Rennlist Discussion Forums |
| All times are GMT -8. The time now is 05:56 AM. |
