Window dead; did broken switch fry motor?
Redirected my 964 turbo after a motor transplant but pass window is dead; tried a combo of all three switches & replaced a bad regulator fuse#4 but window still dead; did the broken switch on pass side fry something common??
Mark |
Did you put 12V directly to window motor? On the passenger side switch, pull the switch plug and connect 12V and ground to pins 1 and 2, I think. I will check my wiring diagram.
I'd like to further diagnose this w/o pulling the door apart if testing the wiring from the switch to the motor doesn't work...but feel I don't have a choice at that point. Pin's 1 & 2 are labeled I assume??
If you have checked you are getting power to the motor I would suspect the motor is seized operate the switch in the down position and tap the motor with a hammer, my passenger side window has a tendency to seize now and again a few thumps on the door card is usually enough to get it working
| All times are GMT -8. The time now is 04:19 AM. |
