-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Leak power steering unit (http://forums.pelicanparts.com/showthread.php?t=685548)
Stian911 06-25-2012 12:20 PM
Just found power steering liquid around the battery. Looks like it's comming from the power steering unit. Anyone who has experienced the same problem? Any tips and hint on what to do?
http://img.tapatalk.com/50ca7f63-b9c6-fddd.jpg
porterdog 06-25-2012 08:59 PM
Hi,
that photo has nothing power steering related in it. What you've pictured is the hydraulic pump associated with brakes and the diff actuators (if you have a C4).
Looks like possibly you have a leak around the lovely green component shown, which is the hydraulic system pressure switch. Check PET to see if there's a seal; if you decide to change it make sure you bleed the pressure off first; probably it'll make a right mess if you don't.
HTH,
PTD
