-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Help! 993 rear axle side sections bushes (http://forums.pelicanparts.com/showthread.php?t=692232)
AlexJ 08-02-2012 07:54 AM
Hi all,
Does anyone knows if the bushes on the side sections at the 993 rear axle (parts # 993 331 051 00 and 993 331 052 00), can be replaced without having to buy the hole section?
Since I've done a major repair on my Carrera 4 (changed shocks, rear arms - all of them - not original but from TWR anyway), I got a twisty behavior of the rear - longitudinally).
I have changed shocks again, fitted back the original elastic arms of the rear suspension, tried 1.567.046 alignment set-ups and... always the same. At the minimal bump on the road its rear looks like a Brazilian ass shacking!!
My mechanic tried yesterday to pull the rear suspension to the front and back and the wheel moves to the front about half inch... the only thing that moves are the side sections (specially left side).
So, I presume the problem comes from those bushes... (????)
The side sections cost a small fortune and it was good if I can have replaced only the bushes...
Bill Verburg 08-02-2012 08:15 AM
Originally Posted by AlexJ (Post 6889465)
Hi all,
yes if can obtain the bushes, AFAIK oem bushes are not available separately
many of us that track our 993s car have replaced the stock bushes w/ solid bushes, Rennline has a nice kit that comes in 2 versions flat and tilt, I'd advise the flat kit and to buy the bolts.
the solid bushes will be fine for a street car too
AlexJ 08-03-2012 07:54 AM
Hi Bill,
Thank you very much for your suggestion.
Do you think normal comfort of an original 993, won't be afected if I fit those?
Bill Verburg 08-03-2012 04:00 PM
Originally Posted by AlexJ (Post 6891421)
Hi Bill,
To a small extent maybe, but i'll take a little discomfort over the stock hip shaking any day
Traveller 08-04-2012 04:30 AM
Those rubber bushings are replaceable with either the OEM or Sport hardness rubber.
They are from the same company that made your OEM busings in your Porsche.
Bill Verburg 08-04-2012 05:25 AM
The bushings are certainly not available oe, you have to buy the whole side mount if you go through Porsche.
If you think that they are available aftermarket, where?
yes the transverse arm bushes are available aftermarket but I've only seen solid bushes for the sides.
Traveller 08-04-2012 05:32 AM
I know.
AlexJ 08-05-2012 06:27 AM
Yes ?! From who?
I am with Bill, I have been searching around and I only found the solid ones...
Traveller 08-05-2012 06:32 AM
Originally Posted by AlexJ (Post 6894382)
From who?
I e-mailed them to see if they will sell to the NA market directly. On certain items they will not due to distribution agreements. I know they will sell to me directly because I'd be picking them up right at the factory.
I'll let you know.
tom_s 08-05-2012 08:48 AM
Elephant Racing just added a listing for these:
http://www.elephantracing.com/suspen...ng-kit-640.jpg
Last item on the bushings page -> ELEPHANT RACING rubber bushings for Porsche 993 and 964
Traveller 08-05-2012 09:03 AM
What a coincidence. ;)
Talk about expensive compared to what I am quoted if I pick them up. Maybe I should become the Canadian distributor. :D
AlexJ 08-05-2012 03:13 PM
Getting better.... But still expensive.... Thank you all for your tips!
Bill Verburg 08-06-2012 04:48 AM
The issue I see is that you will probably also need the aluminum cages that the bushes sit in, they don't come out easily and are usually damaged during the process
http://forums.pelicanparts.com/uploa...1344253681.jpg
AlexJ 08-07-2012 01:45 AM
For the price announced, I thought they were "plug and play"... Imagine taking out the rubbers and fit the new ones on the aluminum caps ???!!!!!!
aigel 08-07-2012 09:57 PM
Can you guys do me a big favor and post a drawing to educate me where these rubbers sit? Looks like something I want to replace down the road!
G
Bill Verburg 08-08-2012 05:04 AM
G
item #6, there are 4 of them
http://forums.pelicanparts.com/uploa...1344427416.jpg
Traveller 08-08-2012 06:28 AM
Like the control arm bushings, you have two choices; buy the complete control arm or replace the bushings and add in your time.
Chuck Moreland 08-08-2012 08:13 AM
Our bushings do include the outer casement and inner core. They are just painted and so do not pop out in the image. You can see them if you look close.
AlexJ 08-09-2012 02:40 AM
That is fine then!
aigel 08-09-2012 08:42 PM
Thanks for posting the schematics. Looks like an upgrade I should have done while the transmission was out. ;) I am glad I missed it. It got a little $$$ after it is all said and done the way it is!
G
