-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Sway Bar Drop Link (http://forums.pelicanparts.com/showthread.php?t=706525)
Bubbling well 09-17-2012 05:39 PM
Sway Bar Drop Link
Hi guys,
On my '91 C2 Targa, I am changing out the old suspension to Bilstein HD and H&R springs and have just finished the rear. Now I am moving on to the front and realized the drop link boots are torn. Here is my question. Since the ride height will go lower, should I go to RS or M03 spec links? Or should I just stay stock for the existing stock sway bar? Also noticed there is a Tarett brand in the market. Does anybody have an experience in using it?
Thanks in advance for your input!
BW :)
Vandit 09-18-2012 05:53 AM
I think the links Tarett sells are Rennline.
Flieger 09-21-2012 07:08 PM
Tarett makes their own antiroll bars so I would think they make Rennline's drop links if anything.
Vandit 09-21-2012 07:18 PM
You're correct. The monoball top mounts they sell are the Rennline pieces.
rs27carrera 09-22-2012 01:40 AM
I believe stock will do as well, but they are pricey to buy so RS could be a solution if going for new.
I had same trouble, boots were gone, but I found that joint was havin no paly at all. I bought another car pall link and took boots from there, worked perfect and cost just pennies.
Erick 09-26-2012 08:58 AM
If you're going to run at RS (or lower) ride height, then I'd suggest the RS drop links.
