Science is NOT optional
rbogh901's Avatar
Bilstein HD shocks, Threaded collars
Merry Christmas to me. I hope to get these mounted soon.
Does anyone know why there is one collar on the rear shocks but two on the fronts?
PCA member since 1993
Old 12-18-2012, 07:54 PM
Probably because the rear assemblies don't turn, only move up and down.
The front assemblies turn w/ the steering, so there's the possibility of the collars turning and losing adjustment. The two collars basically work like a jam nut, tighten them against each other to lock in the setting.
The TEIN coilovers on my Toyota daily driver have double collars on all 4 corners. It just depends.
Old 12-18-2012, 08:19 PM
Bill Verburg's Avatar
I'd want 2 locking the spring perch and 2 for the sway bar mount, 1 above and 1 below
like this
Your sway would probably be above the toe link
Bill Verburg
Old 12-19-2012, 03:13 AM
Remember he has a 964, not a 993.
I just looked at the Bilstein HD/H&R red combo I have chilling in a box waiting to go on the car and they also have the single perch on the rear assemblies.
Old 12-19-2012, 06:00 AM
Oops
Bill Verburg
Old 12-19-2012, 02:01 PM
Good Choice
I like your tastes, I just picked up the same Bilstein dampers with a set of Eibach springs for my 964.
Old 12-20-2012, 08:05 PM
rs27carrera's Avatar
Looks like it's in the air.
I also got week ago new set of Bilstein B6/HD + H&R springs, but have green/blue springs instead. In addition, will install 21mm rear ARB.
Car is 964 C4
These are spring rates I got:
H&R 964 springs (blue/green)
Front 190-255 lbs/inch
Rear 220-265 lbs/inch
H&R 965 (Turbo) springs (red)
Front 250-270 lbs/inch
Rear 265-285 lbs/inch
Kind regards, Harri
964 C4 1992, 930 "RS3.0 looker", Carrera 3.0 1976
911 2.4E 1972 (to be 2.4S+ spec race car), 911 2.2T 1967
Old 12-21-2012, 12:44 AM
rbogh901's Avatar
Well done Gents.
It makes sense that the fronts would turn and therefore benefit from a locking mount. Good point.
How many of you folks are going to install your shocks yourselves? I would like to bench build mine before I take the old ones off. Does anyone have a link showing the correct installation of the washers/spacers, etc?
Old 12-27-2012, 08:25 AM
Enso
Enso's Avatar
Hey I just got a set of Bilstein shocks too, waiting to get some free time
can you tell me why you are choosing the springs you did?
I haven't bought springs yet and am deciding what brand to get
also wanting to see a thread that would help me with installing these shocks
thanks in advance
Glenn
Old 01-02-2013, 09:41 AM
964TargaC2's Avatar
try this
rearsus
Old 01-02-2013, 01:19 PM
Enso
Enso's Avatar
Hey Thanks!
Old 01-03-2013, 06:08 AM
rbogh901's Avatar
I think that link is for a 993. A 964 is very similar though.
Old 03-29-2013, 08:54 AM
KNS KNS is offline
For the HDs , how much adjustment do you get out of turning the collars? If you turn the collar one 360* rotation, typically, how much height adjustment will that get you? A few millimeters..?
Kurt
Old 03-29-2013, 02:48 PM
