Cedric 18's Avatar
964 lost of response
I have been having the same problems over and over almost every time I drive the car, it starts to "cough" and I need to rev the engine to get rid off it, then it's fine. It also sometimes get no response once I step on the gas, just flat!! One more thing, just recently it seems to want to die just idling, I can drive the car but it does not run properly.
I changed spark plugs, fuel pump, did valve adjustment, tune up and replaced distributor caps.
Thanks.
Old 07-03-2013, 10:50 AM
I'd hook up an OBD scanner and see if it's throwing any fault codes first, assuming its a 96 or later 993
Old 07-03-2013, 12:12 PM
If you haven't already done so, check/replace the DME relay (You should always carry a spare).
Old 07-03-2013, 03:14 PM
When were the fuel filters replaced ??
Old 07-03-2013, 04:07 PM
Cedric 18's Avatar
thanks, I will check the DME, the fuel filter was replaced 2 months ago.
Old 07-04-2013, 06:56 AM
crg53's Avatar
There has been a lot of talk over on Rennlist about no response when getting back on the throttle after coasting. I changed out the idle/wot micro switches and now the problem is gone.
Old 07-04-2013, 07:16 AM
bri450sl's Avatar
You may want to check for a vacuum leak as well.
Old 07-04-2013, 04:14 PM
