964 jump start
i had towed my 964 to the Porsche shop for an oilchange + service and the truckdriver could not start the car by arrival (go figur) he jumped started it and now the fasten seatbelt and airbag warning signs are on, according to my Porsche shop he probably reversed the plus and minus and screwed it up causing this.
I did not wanted them to look further into it as it cost $$ and i am obstinate. Further the car drives briljant no problems but the warning light are now on. Anybody? |
Disconnect your battery cables, make sure your battery is fully charged, check all of your fuses, etc., then reconnect cables and see if the system resets.
The air bag wont reset by disconnected the battery.
Did you fix the same problem you had in january .
gotta use the hammer to reset the airbag.
| All times are GMT -8. The time now is 10:12 PM. |
