Need advice on assembling clutch
I'm assembling the clutch on a G50/03, 1992 964, and I'd appreciate some advice. On clutches I've assembled in the past, the throwout bearing was secured to the fork in some manner, but from looking at the fork and throwout bearing on this clutch, I can't see how they're intended to connect or interact. Thanks for any advice you can offer.
There is a c-clip on the exterior of the TB, which you can remove by pushing it and pressure plate, easiest with a press.
| All times are GMT -8. The time now is 12:23 PM. |
