Will I need brake flex line adapters for brake upgrade?
I'm in the process of gathering up my brake components for a big brake upgrade for my 964. Front calipers will be Big Reds 993tt front calipers with 993 rear calipers. Currently I have stainless steel braided Goodridge flex lines hooked up to my stock frt/rear 964 calipers. Will I need to buy new brake lines for this upgrade or will my existing lines simply hook up? Are their adapters I can use??
Many thanks in advance, Dan |
Nope. If what you have fits the 964 calipers, then it will fit the big red/black and 993 rears as is. I did the big blacks and 993 rears and had no issues. Just remove the 964 calipers and install the new ones.
swftiii, very much appreciate your reply. Sounds good, one less thing to think about. Should be a straight up install....
Dan |
As long as you have the adapters for the front to fit the 964 mounting points, yes.
| All times are GMT -8. The time now is 04:51 AM. |
