7.5 X 17 65 mm offset fit 1993 964?
Just bought a set of wheels that were sold as 55mm offsets
9 X 17 55 mm and 7.5 X 17 55 mm Turns out he fronts are 65 mm. Will they fit? Will I need spacers and if so will I have to replace the studs with longer ones? Is it worth the effort? Don't know if the seller is going to help me out. They were misrepresented but .......Thanks in advance. |
My wheels are the same as yours, except the off set is 52 front and 47 rear with 225/45/17 & 255/40/17 and are a perfect fit. Depending on which tire size you mount on the front, you may be OK, but my guess is you will need at least 10 m/m spacers. The rears are fine.
Tags |
964 , rs america parts |
