WTB - 964 3.6 Cylinder
Looking for an updated cylinder for my 964 3.6, Height 5 (Mahle 100 mm). The piston is not required, but will buy as a set if necessary.
Actually have an updated height 6 model that has been re-plated for swap or sale. Thanks! |
Andrea Bichael
You can ask Auto Mechanic to help you for this and to provide you some necessary tips. You can easily get Cylinder for your 964 3.6 from automotive market.
Post a picture
Yep. The one you need.
Not sure that the size is an issue so can be 1 or 2. This is a late model cylinder with ring for head gasket.
Has anyone ever shaved a 6 to use as a 5? Does the 1995 993 use the same cylinder as a 1993 964? The part numbers differ but look like the same part. Thanks biggles,
