964 front calipers
does anybody know if the front 964 calipers can be mounted to the rear in place of the single ones back there? is so what is needed
No, pistons will be wrong way
Get some 951 (944 turbo)rears and flip the crossover pipe and bleeders, straight swap..then either gut the proportion valve or replace with later 0ne
I think that maybe I'm dreaming.. |
Are you adding big brakes upfront? If so you need 993 rears.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
no no big brakes up front,just want the rears to look like the fronts
Schleprock
Get a set of rears that have the same body size as the fronts. Like these http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/860603-4-piston-calipers-964-944t.html
Kevin L '86 Carrera "Larry" |
