-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   turbo springs/struts/shocks on non-turbo (http://forums.pelicanparts.com/showthread.php?t=86363)
lottala 11-04-2002 12:15 PM
Greetings,
I am working on getting some specs together for a suspension upgrade for my 92' C2. From looking at the Bilstein part numbers, they are the same for both turbo and non-turbo models. The H&R spring part numbers, however, are different. From what I can gather, the turbo springs are somewhat stiffer. I have driven a car (only on the street) with a similar setup, which used non-turbo springs, and definitely felt I could live with something a little more aggressive. Now, for the questions:
1) Can I use the turbo springs and will this improve performance?
2) Is there a "cost equivalent" alternative other than Bilstein/H&R that I should look at?
3) Would duplicating the European RS spec suspension be a better option and where can I find the parts necessary (and part numbers) to do this?
Many thanks for any help you can offer!
Tyson Schmidt 11-05-2002 09:29 PM
If you plan on tracking the car, I'd go with Eibach's.
The H&R's are progressive, which is a great compromise for the street. Gives you a nice ride.
But for the track, you really don't want progressive. You want them stiff right now.
lottala 11-06-2002 06:36 AM
springs
thanks for the help, tyson. i do appreciate the feedback.
