-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Name these calipers/rotors please (http://forums.pelicanparts.com/showthread.php?t=872320)
scxtasy 06-26-2015 04:34 PM
Hi,
I have a 964 RS America that I am told has American Roadster calipers and rotors. I'm pretty sure the fronts are "Big Black" calipers on 332x32mm cross drilled rotors, but I am not so sure about the rears. They're definitely not standard, but I can't see any adaptors and the handbrake etc. is still in place and working. Can anyone tell me what I have as I'd like to order new pads and I am unsure which ones to get. Thanks.
Andrew
Front Rotor/Caliper
http://forums.pelicanparts.com/uploa...1435361468.jpg
Front Pad
http://forums.pelicanparts.com/uploa...1435361449.jpg
Rear Rotor/Caliper
http://forums.pelicanparts.com/uploa...1435361483.jpg
Rear Pad
http://forums.pelicanparts.com/uploa...1435361503.jpg
Bill Verburg 06-26-2015 05:07 PM
Originally Posted by scxtasy (Post 8685155)
Hi,
Andrew
Front Rotor/Caliper
Front Pad
Rear Rotor/Caliper
Rear Pad
Those are the same brakes as were used on 964 3.3t
front is not the "big black" it is a variant of the 993 normal front caliper, the pad is a Pagid U1204 which is narrower than the Big Red/Black U1842 pad. It is different from the 993 front caliper in that it has a built in mount extensions for use on 322x32mm rotors, the 993 caliper w/o the extensions is used on a 304x32mm rotor
the rear is a variant on the 964/993 small Brembo rear caliper, it uses U1203 pads, same as 930's did and also same as 964 fronts. This caliper has the larger 30/34mm pistons and is wideer than the other rear calipers for use on 299x28mm rotors as opposed to the 299x24mm used on other models.
What you have is the stock brake setup for your car or for a 964 3.3t
scxtasy 06-26-2015 05:09 PM
Perfect, thanks Bill, that's exactly what I needed to know.
Andrew
