98 cab roof problems
I have a 98 cab with 30,000 miles. This weekend the roof started acting up. At first it would stop about half way. Then it would not move at all. Now sometimes it works and sometimes it doesn't. the top motor sounds like it is trying to work. and the front does clamp down
I did read the manual which states to loosen the two bolts on each side in the rear to be able to close it, which I did.
1. How do you get it to lock after you manually close it?
2. Any ide what might be wrong with it?
Old 07-31-2017, 07:27 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - I'm attaching a link to a thread where this was discussed. There are other threads with this topic as well; just search the keywords '993 cab roof issue'
http://forums.pelicanparts.com/porsche-911-technical-forum/124273-993-cab-convertible-top-issue.html
Old 07-31-2017, 01:35 PM
