-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   This can't be what I read about - 964 flywheel (http://forums.pelicanparts.com/showthread.php?t=96194)
pbs911 01-29-2003 01:44 PM
1 Attachment(s)
I read alot about the dual mass flywheel on the 964 motor. Expecting to see one when I took the flywheel of my 93' 3.6 last night, I found a flywheel exactly like the one below in perfect condition. It can't weigh more than 17-18 lbs, if that. The clutch disc looked as if it was installed last week. Is this the RS lightened flywheel? Anyone knwo what it would be worth?
schubee 01-29-2003 02:07 PM
It's no good, piece of junk. However, I'll take it off your hands. I know you need the garage space for your transplant.
Do you have pictures of the other side. I took a look at a LWF at Andial with the weight they add. I was just wondering if this was one with the weight added. It does look like a LWF. I'll trade you for a stock 964 exhaust system!
Bill Verburg 01-29-2003 02:26 PM
This is what a dual mass LUK flywheel & clutch looks like
http://forums.pelicanparts.com/uploa..._LUK1small.JPG
Very heavy!
pbs911 01-29-2003 02:35 PM
John, is your motor still out of the car? What timing!
There are no weights added to the other side. The motor came directly from Germany so i seriously doubt it is the Andail. If your interested I'll give you a deal on the whole set up: clutch cover, pressure plate, flywheel. Are you going to Dunkles? I'm sure the DME is also chipped considering the complaints about stalling out, but I will not be sure. Next Sunday Ingo is installing a new chip in mine so if there is any way to tell I'll know then.
schubee 01-30-2003 08:51 AM
Paul,
I'm definately interested on the clutch/flywheel deal. I decided not to pull the motor right now. I just replaced a couple oil lines, rotors, new brake pads, and GHL header and exhaust. I drove it today for the first time in over a month. I wanted to clean up the engine to pinpoint other potential leaks. I'll drive it for a couple months and then I'll drop the engine. Maybe I have to upgrade to some 3.8 p/c just to keep up with you!
I'll try and make it to Dunkels on Sunday. Is it on Sunday? Anyway, depending on if my son is in a good mood or not!
pbs911 01-30-2003 09:37 AM
John, sorry but Harald had installed his own personal RS flywheel/clutch set up and forgot to take it off my motor before shipping it. I am sending it back to him. I'll see you Dunkels on Sunday.
Speedster94 01-30-2003 12:07 PM
hallo paul
Thank you very much ,i spend half a Day searching for it and getting Crazy .Whenever we meet the Beer is on me of course .
Harald
