-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   964 IGN Timing (http://forums.pelicanparts.com/showthread.php?t=966875)
guswf 08-17-2017 01:56 PM
964 IGN Timing
I have a 964 with a Varioram running a VEMS ECU. I am trying to dial in the timing. Looking for a base IGN MAP from a VARIORAM 993. VEMS runs MAP and RPM as reference points on the IGN Table. I have attached 3 tables, 1. Stock 964, 2. IGN Timing I used on last Dyno Run. 3. A Motec IGN map from a friend. The first 2 tables have a much greater advance in the mid RPM and Low MAP than the MOTEC does. http://forums.pelicanparts.com/uploa...1503003186.JPG
http://forums.pelicanparts.com/uploa...1503003269.JPG
guswf 08-17-2017 01:59 PM
Well you can tell I am new at loading pictures - Here is MOTEC againhttp://forums.pelicanparts.com/uploa...1503003553.JPG
