Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Brian Minson's Avatar
Driver side cooling fan not working
Hey guys,
Noticed my 2000 996 C4 Tip running a bit hot in the cool 110 degree heat of Phoenix, Arizona in stop and go traffic the last few days, and with the A/C on the temp would touch the mark between 180 and 250.. NOT COOL!
My drivers side radiator fan wasn't coming on with the A/C, but the passenger side was. Switched the relays around and still the driver side didn't work. Ordered a new fan from our host, installed it last night AND STILL NO FAN with the AC ON!
WTH! Any ideas???
Brian
Old 08-01-2018, 06:11 AM
JFP in PA's Avatar
There is a resistor in the power line for each fan, these are a common failure point:
Accrochez-vous bien de vos rêves..........."
Old 08-01-2018, 08:22 AM
JFP, the new fan I purchased from our host came with a new resistor... bad resistor on new part?
Thanks JFP for always replying quickly, you're awesome!
Brian
Old 08-01-2018, 09:20 AM
JFP in PA's Avatar
Could be bad, simple to check with a multimeter. I would also test the power leads to make sure you don't have a wiring issue upstream somewhere.
Old 08-01-2018, 10:09 AM
FPB111's Avatar
Fuse?
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 08-09-2018, 05:31 PM
