997 turn signal doesn't work, but hazard light work any advice?
Hi All,
recently my 08 turn signal both left and right side stop working, (turn on left or right signal stalk on, no blinker in cluster and outside. but hazard light work fine. any advice? Thank you in advance. |
Could be the flasher relay. I've had that happen to my motorcycles. The hazards run via a different relay or a different part of the relay. Might be worth checking out. I think the relay is near the fuse box (under the dash). If hazards work, then turn them on and look for the module that makes clicky noise.
| All times are GMT -8. The time now is 10:59 PM. |
