-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   Name that noise. 99' Porsche 996 engine noise? (http://forums.pelicanparts.com/showthread.php?t=1026857)
pessemist 04-16-2019 06:03 AM
I was finally able to figure out how to post a UTube recording of the engine noise.
The noise only appears after driving about 3-4 miles. Not on startup and not noticed it warming up in garage.
Once the sound appears it doesn't go away even at idle. Seems slightly linked to RPM's (increase/decrease) but not like a direct noise-rpm relationship.
A couple guys listening thought it might be a loose sparkplug or a pully issue. Need expert opinion.
https://www.youtube.com/watch?v=Qle3bhfNizA
pdwhyte75 04-16-2019 06:22 AM
Sounds like a bearing to me, pulley or alternator perhaps?
pessemist 04-16-2019 02:25 PM
Thanks for your suggestion. I had a couple of suggestions as to what it was. I didn't want to just start throwing replacement parts at it and I was worried it might be a deeper issue (valves? Piston slap?)
I took it to a mechanic today and he seems to think is bearing noise from a belt fan pulley as you suggested. We are going to put a new one in and see if it solves the problem.
