no mon no fun
996
My 2001 996 has been sitting for 5 months(with battery tender). What is the best starting procedure? Simply get in and turn the key as usual?
1982sc coupe |
Long periods of time I take the fuel pump relay out.
This way I crank it to prime oil all the way to cams ,tensioners and lifters. Probably 10-15 secs. Put relay back and go. Check air on tires
RSA Pinky Helga Turtle Carrera Luigi CDtdi Last edited by faverymi; 04-03-2019 at 05:12 AM.. |
no mon no fun
996 wake up
Thanks faverymi will do...
1982sc coupe |
My 911 sits for 5 months (or more) every winter. When the snow finally goes i just turn the key.
Has started fine every year for the last 10 years.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
M96 engines have a lot of hydraulic pressurized components.
This way my first start is smoother and doesn't sound like a diesel w marbles running around I'm not a mechanic. I follow advice from my master mechanic |
no mon no fun
wake up
Faverymi is it hard to get to the relay?.. drivers foot well correct?
1982sc coupe |
Yes. foot well. Sometimes they are a little too snug
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
no mon no fun
996
Thanks again...
1982sc coupe |
My 996 can set for a month or two without starting it. The night before I know I am going to take it out I put the charger on at 2 amps. Kinda of like you do the tender.
No problems. I put 40 lbs in the tires because they will get flat spots sitting in your garage and you will notice it while driving until the tires warm up. Other than that. Nothing else. |
