-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   Brake disks change 996 C2 (http://forums.pelicanparts.com/showthread.php?t=1063519)
Paul Silver 06-08-2020 04:25 AM
Hi all.
Does anybody know how much takes to change 4 brake disk and pads by a professional garage, in order to figure out the hour rate price.
Tnx.
Paul
mkaunitz 06-08-2020 04:44 AM
For reference I can do all 4 corners on my car in under an hour. Odds are a shop is at least 2 hrs
Sent from my iPhone using Tapatalk Pro
tonythetarga 06-08-2020 05:51 AM
This is a very easy job with some simple tools. A shop is going to charge you an arm and a leg because it's a Porsche.
If you're not supplying the parts, expect an easy $1k.
Check the list of DIY repairs on the Pelican site or google it. Easy.
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/49-BRAKES-Replacing_Brake_Pads/49-BRAKES-Replacing_Brake_Pads.htm
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/55-BRAKES-Replacing_Brake_Discs/55-BRAKES-Replacing_Brake_Discs.htm
mkaunitz 08-23-2020 11:39 AM
Buy the Sebro slotted rotors on eBay and save a ton of money over the OE rotor as well
