-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   Installing URO Cupholder (http://forums.pelicanparts.com/showthread.php?t=1090085)
dgpnaples 04-03-2021 03:43 AM
I found the URO Cupholder replacement part 997 552 294 03 (see attached photo).
Has anyone replaced one before and if you have can you provide any installation tips.
The first question is does the entire dash have to be removed to remove the old cup holder and install the new one?
Or is there a way to remove the exisiting cupholder and replace without removing the dash. Thank you in advance.
See attached photos.http://forums.pelicanparts.com/uploa...1617446585.pnghttp://forums.pelicanparts.com/uploa...1617446617.jpg
Fracture 04-06-2021 05:35 AM
I'm not completely certain - but I suspect there are spring clips
that pop up - you may need a flat trim tool to depress these
much like a radio
Jetfixr 04-09-2021 08:30 AM
Where in the heck did you find this jewel??
Jet
UROParts 04-12-2021 09:38 AM
Jet
Thanks guys, high quality URO Parts Cup Holder 997 552 294 03 is Pelican part number 997-552-294-03-M253, available here:
https://www.pelicanparts.com/More_Info/99755229403M253.htm?pn=997-552-294-03-M253&bt=Y&fs=0&SVSVSI=0995
Jeff Alton 04-16-2021 08:26 PM
2 screws.....
