-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   2009 911 turbo, engine light, running rough (http://forums.pelicanparts.com/showthread.php?t=1095085)
Debtodd1 06-05-2021 09:45 AM
2009 911 turbo, manual 25k miles. Car started ran fine. Drove 2 blocks when check engine light came on an engine started to running rough like only on a few cylinders.
Was able to limp back to home??? Help! Thanks!
JFP in PA 06-05-2021 10:42 AM
Double posting gains you nothing.
Without codes, anything would be a guess………….
Debtodd1 06-16-2021 10:23 AM
GT3 throttle body failure
This 997.1 911 turbo has an AWE 650 tune which uses a Porsche GT3 larger throttle body which is larger than a 997.1 turbo throttle body.
The electrics on this throttle body failed. I also changed plugs and coil packs.
