porscheguy47
Has anyone had to deal with an oil leak coming from the chain box housing?
Apparently there is an aluminum gasket that can be the culprit?? Must the motor be removed to fix? |
Administrator
Are you positive that's where the leak is coming from? check out some of these oil leak threads. Some have some good descriptions and photos which might give some hints.
https://forums.pelicanparts.com/porsche-996-997-991-forum/1053346-oil-leak.html https://forums.pelicanparts.com/porsche-996-997-991-forum/1047276-what-part-oil-leak-coming-called.html https://forums.pelicanparts.com/porsche-996-997-991-forum/981416-gearbox-cooler-leaking.html |
Its a motor out job. We have replaced a few of the chain box gaskets, and even a cracked chain box its self.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
