996 engine rebuild
Hi all I'm looking at a high mileage 996(110,000), because everybody says that they are prone to engine failure how much is a new engine/ or rebuild? I've tried to search this but never really found anything. Maybe I'm bad at search. The other thing I've seen people talk about is like a buyers guide. People say there are some good ones on rennlist, but I never seem to find them. Does anyone have any links. Are there any other things to watch out for?
A factory 3.4 is over $11K with a rebuildable core exchange, over $13K without a good core. And that comes with a 2 year warranty. You can't get a rebuild done by a reputable shop with a similar warranty for less than that.
The big failures with these engines usually destroy so many expensive parts that it's just cheaper to buy a new engine than rebuild. |
You need to read the Excellence Tech Forum article "M96: Past, Present, and Future", in the December 2008 edition. It was followed by a shorter Tech Notes response to a reader question titled M96 Engine Design in the May 2009 edition. These two articles will answer all of your questions.
Eric 1978 spec 911 1998 C2S |
Thanks for the replies. Earlyapex where do i find that article is it on this site? What exactly fails? I'm guessing it will say in the article
Thanks I didn't know of excellence magazine I'm pretty new to 911's and porsches in general
-Pierce |
Welcome to the Porsche community.
I just did a quick search on eBay and there were no 996 engines for sale right now. There were a couple of 997 ones tho. Would a 997 engine fit in a 996?
_______________ Henrik '85 Carrera Coupe Black on Black |
Formerly reformed
It depends on your definition of "fit" . . . specifically, how much are you willing to pay to make it work. Fit is generally not an issue; it's the peripherals that make it interesting.
1968 911P (Paperweight) |
997 into 996
I am interested in this also--too make it simpler-- lets presume an 02 996 with tip . would that be a bolt in deal. What would need to be changed? Would taht apply to a 6 speed as well?
They can rebuild your motor...bigger...stronger...faster...but I'm not sure on pricing. I know Boxsters can be had for the range you mention. Can't be that much more for 911s?
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
In answering the 997 engine into a 996..... the electronics is the expensive part. The 997 are egas meaning electronic gas petal. So if you are already egas it might be worth looking into further. Engine plus electronics to make it work means bigger bucks. I'm a lite weight so I went for a factory rebuild swap on my 99 Cabrio. Good luck!
TRUST me when I tell you you want a newer car that hasn't been driven by the devil. When you start paying someone else to work on these cars, you are financing their childrens college education at 75-$95 per hour. If you are hell bend on an older 1st Gen 996, try LA Porsche Dismantler at http://www.ladismantler.com/index.php?page=cat_list&cl=14&cat=2913 they are the largest source of Used Porsche Parts on the Web. Good Luck.... J |
