Closing Sunroof
I purchased a 2000 996 C4 a couple of months ago, and am very happy with it. However, being the pessimist that I am, I keep waiting for something to break. Well, the sunroof got stuck with the back side up
My mechanic wants $100 just to diagnose the problem . I trust him, but don't want to put the money out right now. Is there a way that I can manually close the sunroof I appreciate any advice or suggestions... TIA
Larry ![]() "We are the youth you crummy bastards, we are the youth" Harry the Hipster ![]() 1974 911s 2.7L Olympic White w/Red Leather interior 1991 928 S-4Guards Red SOLD 2000 911 996 C4 |
Yes, you can look it up in your manual but what you have to do is pry out the two black sensor covers in your overhead dome light console.
Unscrew the two screws under those, and then the whole console can be unclipped...just pull down. Then you'll see the tool which can be used to manually wind the sunroof closed. It may just need a lube, maybe the switch is hooped....there's also a retraining procedure floating around. I might be able to dig it out if you can't find it.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Jasper thank you for the instructions. I followed them to a tee, and was able to manually close the sunroof. I was in a rush, and didn't have time to locate the problem; however, I plan on going back in and seeing if I can diagnose the problem. Once again, thanks Jasper for the excellent advice.
Larry
Did you figure out what the problem was?
No, I've been a little busy the past couple of weeks. As I posted, I was able to get in and close it, and next week I will get back in there and take it all apart and maybe take some photos on the repair. Thanks for checking.
Larry
