-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   3.6L engine in a 3.4L 996 (http://forums.pelicanparts.com/showthread.php?t=704218)
txhokie4life 09-11-2012 04:37 PM
I see in the Boxster Tech forums that the 2001 Boxster has most of the CAN features
implemented in preparation of the 7.8DME.
Is this also true for the 2001 996?
I have a 996 3.6L Engine looking for a home and I'm considering picking up
a 996.
There are quite a few 3.4s having issues and considering options.
thanks,
Mike
N3LLYNOVA 12-13-2012 01:40 AM
What year and how many mileage is your 996 engine? X-51?
cretinx 01-02-2013 02:18 PM
You'll have more fun if you put it in a Boxster
BoxsterGT 02-18-2013 03:18 PM
The X51 is 3.8 ltrs.
Len
BYprodriver 02-19-2013 09:20 AM
Len
Not in a 996
bell 02-19-2013 09:44 AM
I did an x51 from 05 into a 2000 996, you need an external fuel pressure regulator, change pins in about 20 errors, and run 4-6 from the engine bay to the dme.
You will need to rig up the a/c to work and you will lose cruise control.
You will need a 7.8 dme, but that's it really.......you also need to use the original water temp sensor.
