-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   Fault code 0234, any advice? (http://forums.pelicanparts.com/showthread.php?t=756553)
brock911 06-17-2013 06:35 PM
02 Turbo... Identified a "0234" fault code today = "Turbo - Super Charger Overboost condition".
The car runs good without hesitation upon acceleration and no odd behaviour.
I did have a CEL diagnosed by the dealer as 0491 and 0492 relating to SAI system but I'm not sure if the two are related, any ideas what I might be up against?
Online search reveals the following...
OBD Code P0234refers to
The PCM disables (bypasses) the supercharger boost and sets a diagnostic trouble code (DTC) to keep from damaging the powertrain (engine or transmission) during potential harmful operating conditions.
Symptoms
Possible sumptoms of OBD code P0234
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0234
- Brake torque (brake on and throttle at wide open). - Transmission oil temperature (TOT) exceeds calibrated threshold. - Engine over temperature. - Ignition misfire exceeds the calibrated threshold. - Knock sensor (KS) failure
Possible Solutions
Check for other diagnostic trouble codes accompanying P0234, or check appropriate and available PIDs related to the above possible causes.
