Fault code 0234, any advice?
02 Turbo... Identified a "0234" fault code today = "Turbo - Super Charger Overboost condition".
The car runs good without hesitation upon acceleration and no odd behaviour. I did have a CEL diagnosed by the dealer as 0491 and 0492 relating to SAI system but I'm not sure if the two are related, any ideas what I might be up against? Online search reveals the following... OBD Code P0234refers to The PCM disables (bypasses) the supercharger boost and sets a diagnostic trouble code (DTC) to keep from damaging the powertrain (engine or transmission) during potential harmful operating conditions. Symptoms Possible sumptoms of OBD code P0234 - Engine Light ON (or Service Engine Soon Warning Light) Causes Possible causes of OBD code P0234 - Brake torque (brake on and throttle at wide open). - Transmission oil temperature (TOT) exceeds calibrated threshold. - Engine over temperature. - Ignition misfire exceeds the calibrated threshold. - Knock sensor (KS) failure Possible Solutions Check for other diagnostic trouble codes accompanying P0234, or check appropriate and available PIDs related to the above possible causes. |
