-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/forumdisplay.php?f=269)
-   -   Window Drop Down Switch ? (http://forums.pelicanparts.com/showthread.php?t=839130)
David 84 911 11-17-2014 05:27 PM
2002 996 4S
My door handle activates the window drop down OK but as soon as I release the handle to shut the door, the window goes up right away before I have time to close.
Anyone think this part from our host will solve the issue ?
"Window Drop Down Switch on Door Handle (Right) $44.00"
Thanks David
jbsiii 09-03-2015 07:40 PM
Hi David,
I have exactly the same problem on the driver's side. Did changing the switch fix the issue?
John
GromitInWA 09-03-2015 11:44 PM
The best thing to do would be to take door panel off so that you have access. There is a switch for the interior handle, another for the exterior handle and multiple inside the latch mechanism itself. The handle switches can be tested for continuity using a multimeter. If they work the you need a new latch mechanism.
Jeff Alton 09-04-2015 08:49 PM
Two systems control this function. The first is the microswitch in the handle, which appears to be working. The other is a microswitch that is part of the latch. If the window immediately goes up when you release the handle, the latch thinks the door has closed, so that is where your problem is. The live data can be viewed with a Durametric or quality scan tool.
Cheers
gshase 11-03-2015 02:12 PM
Thanks Jeff.....I just went out to open the door panel to address the window issue and sprayed the door latch with silicone lube and it fixed my window issue.
