Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
I like Orange
Cookie Porsche's Avatar
915 Racing Clutch
I have a 3.8RSR engine with a 915 gearbox. Funny enough the gearbox is holding up fine.
The clutch is the problem.
I had a modified alu press plate that worked well for a while. Now its toast.
The 4-button spring center clutch is looking fine and so is the flywheel.
Please tell me what setup to use - and YES, I have searched!
Who sells a clutch KIT that can handle some 350bhp for the 915?
Regards, Tom
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 03-29-2006, 09:19 AM
914 Geek
It may be overkill, but have you looked into:
http://wevo.com/wevosuperlite.htm
--DD
Old 03-29-2006, 01:51 PM
I like Orange
Yirkjh%$nkmsdfgv£.
$3000+ WITHOUT the Tilton clutch (and I actually only need a clutch/pressureplate).
My flywheel is already fancy.
Who sells a good pressureplate (Centerforce?) that will simply bolt onto my 'standard' 915 flywheel?
BTW: I do use the WEVO gearshift / coupler and they are super products.
Tom
Old 03-30-2006, 06:49 AM
914 Geek
Hmm, sounds like overkill of the "thermonuclear warhead" level.
Umm, maybe Kennedy? They've been known to supply a dizzying variety of clutch parts for various applications.
Oh--and when you're talking to your clutch parts supplier, you might want to specify the (rough) level of torque your engine is making, not the HP. I believe that it is torque that spins the clutch disk loose from the pressure plate, not HP.
--DD
Old 03-30-2006, 09:02 AM
I like Orange
Dave, thanks so far. Very silent in here!
You're right about the torque v bhp - nobody cares about bhp these days...
Engine makes +/- 400nm (some 295 ft-lbs me thinks) @ 5200rpm.
Clutch experts - WAKE UP.
Tom
Old 03-30-2006, 11:21 PM
ted ted is online now
likes to left foot brake.
ted's Avatar
I have a CenterForce clutch from Patrick racing in AZ.
350hp/915 combo.
Next time I think I will have Jae at Mirage International in San Diego respring my Sachs racing preasure plate and run a puck disc with it.
Contact for Mirage is 1 858 581 1101.
Tell him you saw it on Pelican.
BTW Jae's track car is a 400hp 3.8 with a 915 too.
Old 03-31-2006, 08:46 AM
Mahler9th's Avatar
I have a 3.8 car here in NorCal. A bunch of us run big HP through 915s... The cat's pajamas are the old Sachs rsr parts. No one seems to have them any more. I am told that is the only thing that always works for big bhp besides Hayden's Tilton set-up.
If you contact parts at Sporthaus in Reno, Duck Fuson may know of a newer solution.
Good luck.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 04-02-2006, 10:10 PM
Jeff Alton's Avatar
Give the boys at Kennedy Enigineering a ring.....
Cheers
www.turn3autosport.com
Old 04-02-2006, 10:54 PM
mm86911's Avatar
I've heard good things about Kennedy also
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 04-03-2006, 01:40 PM
I'm running my 915 behind a 350ci SBC in my 914.
It had the sachs alloy PP and a puck disc in it which where toast, though they did hold up for a good bit of abuse.
I'm hoping the comments on the rsr part are correct. I just snapped up an alloy rsr pp to be resprung and a kevlar disc to go with it. I'll let you know how it fares.
Oh, and I'm at about 365 lb torque.
Michael
74' 914/8 SOLD
Old 04-04-2006, 09:52 AM
I like Orange
I have just ordered the Kennedy Stage 2 Alu Pressure Plate.
Does anyone have any knowledge about this item?
Tom
Old 04-05-2006, 08:14 AM
