Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
74goldtarga's Avatar
Pagid Orange or Black?
My 944 Turbo weighs about 3000lb. I have new slotted discs and will have new brake scoops or ducts for my next track day, my wheels also allow better airflow than previously (D90 vs Flatdish). I have run Porterfield R4 in the past but want to try Pagid pads - people have recommended orange and black to me. What criteria should I use to choose between the two compounds? I am running DE only, no races. I want a consistent pad that is as gentle on rotors as possible with good wear. My club runs at brainerd and road america which have very long straights/high speeds and long braking zones. I have had problems with pad deposition on rotors causing pedal and steering wheel vibration in the past and really want to avoid this, obviously I don't want fade either. I bleed brakes before every event and have fresh Super Blue in the system. Thanks for your advice/input in advance.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 06-28-2009, 05:43 PM
Tom W's Avatar
Neither. The orange are old technology and really dusty. If you run "drilled" rotors, they will constantly clog the holes. The black are pretty aggressive for DE. I suggest the RS-19 yellow pads for DE.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 06-28-2009, 05:53 PM
Thanks Tom. I always get more confused rather than less in this area of braking. I would really like to find that bulletproof setup. I have never heard of RS-19 yellows, I will try to look them up.
Old 06-28-2009, 06:06 PM
38D 38D is offline
38D's Avatar
Black have more stopping power, yellows last a bit longer (but are also a bit more expensive). I personally run blacks front & rear and wouldn't consider anything else.
Oranges blow. They overheat and you get tons of pad transfer on the rotor.
- Colin
GTC Motorsports, PCA Club Racing National Scrutineer
'92 Euro Cup #96ZNS498058 (PCA GTC1 #19)
Past '91 C2 Turbo (PCA D Class #38), '04 Cayenne S, '74 914-6 3.2 (236rwhp), '02 986S M030, '71 914-4 2.1, '76 914-4 2.0
Old 06-28-2009, 07:21 PM
Pad transfer is what I am trying to avoid. Thanks guys - yellow or black then.
Old 06-28-2009, 07:54 PM
Super Moderator
cstreit's Avatar
Pad transfer is exactly why I switched to PF97's. Work great, good rotor life, inexpensive.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-29-2009, 06:14 AM
earlyapex's Avatar
I've been running PF97's and second Chris' recommendation.
Eric
1978 spec 911
1998 C2S
Old 06-29-2009, 09:48 AM
