Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Alter Ego Racing
ErVikingo's Avatar
Spec cayman racing
Guys, hope I'm not breaking any posting rules. I got an email from a friend and fellow Porsche racer. Sounds interesting:
This is just out and to be announced at the HSR Mitty in Atlanta!!!!
Do you love Vintage Racing, but hate the maintenance expense? Now you have an option!!!
There is a new Spec Cayman Race Series starting with in the HSR Group!!!
This is going to be HOT!!!!, There have been 30 cars made available by Porsche, that will be made race ready, there are a few options you can add or change... These are the new Gen. 2 Cayman and Cayman S Cars!!!!
There are some great names involved, Jack Baldwin will be the technical director, and more to follow...
These cars are eligible for both Spec Cayman/ Cayman S in HSR and PCA...
If you are interested in this program and Cars please let me know... I will get you HOOKED UP, for about the same price of a 2.0 911 or less, and without all the extra expense of maintenance.
I can be reached at this email or the cell number below...
Please Pass along to all your racing friends!!!!!
Paul Goyette
904-651-0465
918 Mineral Creek Dr.
Jacksonville, Fl.32225
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 04-15-2009, 06:13 AM
Alter Ego Racing
ErVikingo's Avatar
Rules:
Only 2009 Cayman and Cayman”S” cars are eligible. Must compete with full road equipment and, with the
exception of exhaust/emissions, be street legal as designed by the factory, capable of being registered for street use in the condition of the car when presented at scrutineering, and capable of being driven to and from the event. All cars are required to have a Historic paint scheme. [Example; Martini Racing, Rothmans, Gulf, Hippie Car, etc.]
1. Engine
A. As delivered from factory. No modifications after the air filter or before the exhaust headers.
B. Stock, fuel injection must be retained.
C. Exhaust system is free providing the engine meets any local noise limit requirements.
D. Machining for balancing purposes only is allowed.
E. Air conditioning belts, hoses, condensers, compressors may be removed.
F. Radiators are free. Radiators must be installed in the stock location. Anti-freeze is prohibited.
G. Oil coolers are free.
H. Wet sump engine oil pans to prevent oil starvation is permitted.
I. Any dual mass flywheel may be replaced with a single mass, ferrous material (magnetic) flywheel.
J. An underdrive pulley on the crankshaft for the power steering belt may be used.
2. Suspension
A. Suspension pick-up points must remain as stock in location and type.
B. Additional flat metal may be welded to reinforce suspension mounting points or suspension pieces. Added
material may not connect with roll cage components or otherwise provide chassis stiffening beyond the repair
of worn areas.
C. Spacers to adjust the height of the steering rack and pinion are allowed.
D. Shock absorbers are free providing they are of the same type, using the same pick-up points, as supplied
by the factory. Remote reservoir shocks prohibited
E. Any suspension setting not requiring machining or modification of factory parts is allowed.
F. Spring type must remain as supplied by the factory.
G. Spring rates are free.
H. Sway bar sizes and configuration are free except driver-adjustable sway bars are not permitted in the cockpit.
I. Suspension bushing materials are free. Replacement of suspension bushings cannot alter the suspension
geometry of the vehicle.
J. Any bolt-in shock tower brace is allowed.
K. Toe links may be replaced
L. OEM two-piece lower control arms {GT3 Type} are allowed
3. Tires and Wheels
A. Any DOT approved, nationally marketed, generally available, “road race version” tire is allowed.
B. Tread must be a minimum 2/32” over 2/3 of the tire at the start of each session (practice, qualifying, race).
There must be visible tread remaining on the contact surface of the tire at the end of each session.
C. Wheel type, style, and diameter are free, providing wheel meets or exceeds factory safety specifications.
D. One inch wider than originally supplied wheel and any tire combination which fits inside the stock body
without rubbing and without modification exceeding “rolling” or “grinding” of the outer fender lip is allowed.
4. Brakes
A. Brake pad material is free.
B. Brake calipers and rotors must be as supplied by the factory. Cayman “S” brakes allowed on Cayman.
C. Grooving/slotting/cross drilling of rotors is allowed.
D. Ducting of air to rotors is allowed.
E. Removal of dust shields (backing plates) is allowed.
F. Brake fluid is free.
G. Master Cylinders must be as supplied by the factory.
H. Replacement of ABS control unit with any non-programmable unit that cannot help
with traction control is allowed. Associated changes to uprights and wheel sensors are allowed.
5. Transmission
A. Ratios of ring and pinion and individual gear sets must be as supplied by the factory.
B. Transmission coolers are free.
C. Only limited slip differentials (LSD's) derived from a mechanical type that was delivered in a street-legal
Porsche is allowed. No locked differentials will be permitted.
D. Modification to, or substitution of, the shifter mechanism which reduces the range of motion is allowed.
6. Body/Chassis/Interior
A. Removal or substitution of components, other than those specifically indicated below, is not allowed.
B. Chassis/body, with the exception of bumpers and spoilers, must be the same material and configuration as
supplied by the factory. Sheet metal modifications in the spare tire compartment as required
for installation of a fuel cell are allowed.
C. Ducts mounted through the bumper for oil coolers are allowed; headlights must be retained
and body panels cannot be cut.
D. Lexan windshield and rear hatch window of appropriate thickness and quality of construction are allowed.
E. Seats are free providing minimum weight of vehicle is met. Any ballast to meet weight must be placed entirely
in the driving compartment and be securely bolted to the chassis.
F. Steering wheels and shift knobs are free.
G. Spoilers and bumpers/air dams are free providing they do not exceed maximum factory body width by any
amount and maximum factory body length by more than 1 inch.
Turn signals, headlights, parking lights and tail lights must be retained in any bumper
replacement. Rear spoilers incorporated into deck lids are allowed.
H. Modifications to the underside of the vehicle for the purpose of improving aerodynamics are not allowed.
I. Interiors, with the exception of seats (which may be replaced, not removed) and the panels affected by the
installation of the roll bar or roll cage must be as delivered by the factory. Additional gauges may be added but
the stock dash must be retained. Any rear view mirror is allowed.
J. Headliners may be removed for installation of welded-in roll cages.
K. Airbags may be removed.
L. Loose trunk carpet, floor mats, or hatch carpeting may be removed.
Carpet in driver footwell may be removed. Sound-deadening material may
be removed.
M. Spare tires must be secured or removed.
N. Any Porsche factory exterior mirror from a street car is allowed.
Old 04-15-2009, 06:14 AM
Alter Ego Racing
ErVikingo's Avatar
I was just informed that there are 30 SPEC Cayman S and Cayman's available.
Old 04-15-2009, 07:06 AM
I applaud any Porsche racing.
Interesting that it is both the normal Cayman and the S. Wonder why two models? Would not everyone just chose the S?
Would be cool if converted to race spec by Porsche or there agent like the cup cars and supplied with roll cages, competition seats, and safety equipment. Or at least a factory kit. This could add an element of value to the cars.
Love to see a Club Sport w the only option being A/C.
Combining a historical race org w new Porsche's is interesting. Bet it is a business decision to boost both in the recession.
Old 04-15-2009, 07:33 AM
Alter Ego Racing
ErVikingo's Avatar
Perhaps to move cars sitting in lots also. In any case, it shoudl be pretty neat!
Old 04-15-2009, 07:53 AM
Plavan's Avatar
Juan,
Do they take kidneys- or 20 year financing?
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 04-15-2009, 08:34 AM
Alter Ego Racing
ErVikingo's Avatar
perhaps first born? I'm trying to find out the cost.
Old 04-15-2009, 08:40 AM
Max Sluiter
Flieger's Avatar
Are these the Cayman S Clubsport cars being developed in Germany now? The word is they will be 100kg lighter with carbon fiber and Aluminum body panels, have some trick mechanical bits like limited slip differentials, and have the same engine tuning.
Old 04-15-2009, 12:25 PM
38D 38D is offline
38D's Avatar
Is this a factory car, or sometime that a shop is building? If it is a factory car, what is the cost and who can we contact to see about buying one?
- Colin
GTC Motorsports, PCA Club Racing National Scrutineer
'92 Euro Cup #96ZNS498058 (PCA GTC1 #19)
Past '91 C2 Turbo (PCA D Class #38), '04 Cayenne S, '74 914-6 3.2 (236rwhp), '02 986S M030, '71 914-4 2.1, '76 914-4 2.0
Old 04-17-2009, 09:21 PM
juicersr's Avatar
Originally Posted by ErVikingo View Post
Perhaps to move cars sitting in lots also. In any case, it should be pretty neat!
Wow, the idea that Porsche might support racing a production model other than the 911 truly boggles the imagination
I guess out of desperation, the marketing guys have decided now that all the slick ads and BS have failed, they have to do SOMETHING with all those Caymans gathering dust on showroom floors. Maybe some of the bean counters running the company now known as Porsche have finally realized that they cant keep mining the legacy of the real Porsche company indefinitely.
I try not to be cynical about modern Porsche (might be too late tho), which every year moves further and further from the ethos of Dr Ferry, but i will not be surprised if they jack the price of these cars up thousands for the 'privilege' of 'racing' them. I can just hear the Porsche board room now, 'hey, Wendelin, i got it, lets create a racing series just for the Cayman with HSR with virtually no investment on our part (hey, just some new paint and stickers), and gouge ( i mean charge) our customers mark-up on the cars (plus other fees)... hey, it's worked for lame models like the RS60 and Targa Florio Spyder... i guarantee we can move a ton of 'car units' like this!!! Oh, BTW, do the cars have to have manual transmissions? We have all those automatics too, and that would be good for our soccer mom and country club golfer target groups'
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 04-18-2009, 11:20 AM
Alter Ego Racing
ErVikingo's Avatar
The organizer of this series posted the following which clears up some of the doubts above:
Old 04-18-2009, 01:39 PM
Alter Ego Racing
ErVikingo's Avatar
The "Cayman Interseries Championship" is to be run in HSR. Porsche AG, PCNA or Porsche Motorsport is not involved in any way. This is a program that HSR has been working long and hard to develop and has been formed expressly by me and sponsored by Napleton Porsche. Although the cars fit into many race groups with SCCA, Porsche Club,NASA,etc.,the purpose of the series was to make available cars that were ready to be modified and have cool single marque championship series to run in HSR. Thanks, Ron Barnaba
juicersr's Avatar
Fantastic, sounds like the making of a great series.
The Cayman really does have excellent potential that is just beginning to be realized... hope this is just the start and that the factory will develop the platform.
dzugautomobili.com
Old 04-18-2009, 02:41 PM
BoxsterGT's Avatar
Porsche Crest
Any updates on the 2010 events scheduled for the Cayman? Would love to see them in person.
Len
Old 06-02-2010, 08:42 AM
gearhead
Napleton Motorsports
The next one is the weekend of June 10th-13th.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-02-2010, 12:16 PM
