Macan oil temp
After checking out the Audi Q5 and the BMW X3, we just purchased a new Macan (base model) last week. We just love the handling and the interior layout.
One question I had was concerning the oil temperature. Ours seems to run at ~217F when fully warmed up in stop and go traffic. Is this typical? Just wondering what the average operating temp should normally be (The water temp rises to 200F and stays put). Thanks!
commandant of the compound |
Our Macan S runs with water temperature of exactly 200 deg F as does yours. Water circulation (pump activation) seems to be controlled by the ECU to maintain this. Oil temp varies a bit above and below this.
Think you are AOK.
2015 Porsche Macan S, Dark Blue Metallic 2011 BMW 328xi, Crimson Red |
Functionista
Worked on hundreds, normal.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Yep, definitely normal. Mines is at 217 when fully warmed up as well.
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
Thanks everyone!
I also recall reading on a different forum that the oil temperature runs lower when sport mode is engaged, although I have not seen this.
