-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Cayenne drive line shudder (http://forums.pelicanparts.com/showthread.php?t=1033278)
911buff 06-27-2019 09:11 AM
While driving our ‘08 base Cayenne, it suddenly began to shudder, fairly violently. It feels like it is coming from the right rear but it is hard to pinpoint. It starts at about 20mph. However, if I take it out of gear it almost completely disappears. Nothing is visibly out of sorts and everything is tight (wheels won’t wobble, half-shafts feel normal, etc.). Has anyone had this issue before? If so, what was the cause?
island911 06-27-2019 09:53 AM
center drive shaft bearing. (actually the rubber mount around the bearing.)
Common issue.
island911 06-27-2019 09:57 AM
here you go... https://forums.pelicanparts.com/porsche-cayenne-macan-forum/673971-04-cayenne-drive-shaft-bearing.html
and my write up http://forums.pelicanparts.com/porsche-cayenne-macan-forum/645350-drive-shaft-bearing-issue-dont-buy.html
911buff 06-27-2019 04:36 PM
Thank you for the advice, right on the money. The rubber is torn!
Question; the Cayenne is about 8 miles from the house, can I drive it home (carefully) or do I need to tow it?
island911 06-27-2019 11:09 PM
I would drive it, shifting into neutral when possible.
Or I might get MacGeiver on it where it sits... One guy zip-tied some rubber tube sections to fill the gap - think zip-tie thru a piece of say fat-wall fuel line, then wrapped around the outer ring.
island911 06-27-2019 11:16 PM
Not the one I was thinking of, but theres this..
http://forums.pelicanparts.com/uploa...1561702497.jpg
5/8" diameter x 1" long
911buff 06-28-2019 06:24 PM
The repair is complete using the “Jimmy” method. Nine one inch sections of 5/8” OD heater hose and a coke can to slide it on with. Took it for a ride and no vibration!!! Thanks for the advice.http://forums.pelicanparts.com/uploa...1561771258.jpg
A few of the leftover pieces. Used wire to secure together and to the bearing carrier
Mike80911 06-28-2019 06:56 PM
If you replace it get the lifetime one from vertex. I replaced mine with a rebuilt driveshaft unit and it gave up in a year I then used the lifetime one and it is still in the car after almost 100K miles
guru944 07-11-2019 03:49 PM
Oh Yes, We must all do this upgrade...I did my in December 2016. It took me almost +2.5 hrs to complete, not 1hr as advertised. Well worth it. No more noise or shuddering especially during hard acceleration.The EPS/Vertex Intermediate Shaft Support Bearing upgrade is "Peace of Mind" and Lifetime.
Love My 955S Ti with great passion.
fintstone 07-23-2019 08:40 PM
My 2004 CTT is well north of 100K mi and I have not replaced this item. Since I may not get a lot of notice when the time comes, I have a question (based on the posts here). Is the recommended fix here the "Porsche Cayenne Turbo Cayenne Updated Drive Shaft W/ EPS Bearing Support" that comes complete with driveshaft and support?
...or is it to install the EPS Driveshaft Repair Clamping Support Mount without removing the driveshaft? https://youtu.be/t9b271NLwSE
Pelican has a writeup on this: https://www.pelicanparts.com/techarticles/Porsche-Cayenne/29-SUSPEN-Driveshaft_Bearing_Support_and_Flex_Disc_Replaceme nt/29-SUSPEN-Driveshaft_Bearing_Support_and_Flex_Disc_Replaceme nt.htm
island911 07-24-2019 08:19 PM
If I had to do it over again I would use the “Jimmy” method above. Or perhaps something of my own design. :cool:
Replacing the drive shaft can be a real PITA (removal). And is costly shipping, and is throwing away quite a lot just for a new rubber bumper.
Replacing only the bearing and mount is what I did.
I don't care for the inelegance of the clamping replacement. --yes, I see the “Jimmy” method as being more elegant as it doesn't require using a hack-saw and over $400.
