Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
jrblackbox's Avatar
airbag light on 2004 S
So, I have had the airbag light on for a while, always thought it was the switch under the drivers seat. Had a friend read it, "Side airbag triggering unit, passenger's " . how do I correct? TIA
Old 06-19-2019, 05:35 AM
I went through over 3 years of trying to get the air bag lights off. If you are talking about the light that says "passenger air bag off" the final solution was for the dealership to reset/program the passenger seat weight parameters. If you are talking about the dash ICON the final solution was to replace the dash wiring harness. However, the codes that the dealership and the independent garage came up with did not include "Side airbag triggering unit....." Good luck! Your going to need it.
Old 08-01-2019, 06:05 AM
Information Junky
island911's Avatar
http://forums.pelicanparts.com/porsche-cayenne-macan-forum/529043-side-airbag-fault-warning.html
Old 09-02-2019, 08:39 AM
